camusterrach
New Member
Hi
I changed the joker valve on our 2 year old Jabsco manual toilet when the boat was out of the water. I checked that the valve I put in was identical to the one I took out. Now the boat is in the water again would'nt you know that the heads leak at the bottom of the pump. With water in the bowl it leaks slowly from the base of the pump, where the base valve gasket goes. When you pump it water gushes from the discharge flange. I have taken it off and tried reseating it several times but there seems to be gap at the back where the discharge pipe meets the flange which I cant seem to get shut. Anyone any ideas on reseating the gatkets/flange and pipe?.
No limp jokes/puns/alliterations please, already had all those from wife.
Camusterrach
Camusterrach
