drakes drum
Like many of 'us' Paw Paw started to suffer from permanent droop and sagging and we decided that professionals were needed to totally replace the headlining.
Having searched the net we contracted Spencer Marine Ltd for £9,000 to travel to Gibraltar and replace all the Vinyl.
We did not see the finished job until after it was completed and both Louise and I were distraught. So horrified and disappointed. Have a look, if you like, at the pictures of the finished work - http://www.michaelbriant.com/new_page_68.htm
It maybe that I am becoming a grumpy old git and expect too much but having done the replacement headlining job once myself on a Prout 33 I did expect 'professionals', for lots of money, to have done at least as good a job as I had done.
Have others had similar experiences with Spencer Marine or other companies? Can you recommend anyone as I am 100% certain it is all going to sag again in a year or so as automotive headlining adhesive has been used rather than marine contact glue like SAF111 which should be applied to the GRP and marine spray like Trade Track or similar to the foam backing.
Have others used automotive aerosols successfully on their boat headlining?
Michael
I must be dim but no way can I find the piccies of the roof lining on that link. For that matter I can only see bits about a prout cat
