NealB
I've just replaced Arendala's zinc anodes, and used these fixing bolts:
01007: Bolt On Stud 10mm Diameter with nuts and washers | Anodes Direct
I didn't take any pics, but here's what I did, in words.
I took the two nuts, two washers, and two wire connectors off of the 'long' end of each bolt.
I pushed that long end through from the outside of the hull, so that the thick, fixed, washer on the short end, butts up against the underside of the hull (yes, with a few turns of caulking cotton, and a good 'squeeze' of sealant).
Is that the right way round, or should I have pushed the short end of the bolt through from inside the bilges (so the thick, fixed, washer would butt up against the inside of the hull?).
Does it matter?
Thanks for your thoughts.
Does it matter?
