chuzzlewit
It stopped working. After switch-on the fuel pump would pulse and the heater would fire up for about 20 seconds with warm exhaust smoke then go cold. Voltage at glow plug (which looked clean when I extracted it)was only 8.5V.Tracing and cleaning all connections between battery and plug looked a nightmare. So I lead a heavy 6AWG fused double cable from battery to plug with a relay (switched on by voltage from original leads to glow plug) in the positive lead.
Now when I switch on the fan blows. There is no longer a pulse in the fuel line. The voltage at the fuel pump(which isn't pulsing) is a steady 4.5V. No voltage comes from the wires that originally powered the glow plug: so the relay isn't activated. This state of affairs continues indefinitely.
Any advice gratefully accepted.
