Steve_Jones
Having just moved to a house near the Thames, I was exploring the neighbourhood in our tender (inflatable dinghy) with a 2.4 HP Johnson outboard. After running ok for about an hour at 1/3 throttle the engine suddenly lost revs and died. There was obviously an overheating problem as the engine was making a 'crackling' sound like a car exhaust when it cools. The engine appeared totally seized for a minute or so after which I was able to turn it over using the starter cord. In the meantime I had checked the cooling water inlet on the leg and found it was totally clogged with leaves. Once this was cleared and the engine cooled I started it and ran it in neutral for a while to get some cooling going and to check the flow from the tell tale.
Being a newbie to rivers, is this a common problem and how do I overcome it? Also, what damage might I have done? Is a full strip-down of the engine required? The outboard ran ok for about 30 mins after this (we needed to get home!) and it appeared ok, although it sounded slightly 'rougher' than usual, or did I imagine it?
As always, thanks in advance!!
Cheers,
Steve
Cheers,
Steve
