Hatch runner material
perlonious
1 Jan 2003
Bucks
hihi
any diy shop......draft excluder....but u may be better changing the system if u can to metal runners, as it slides much better and will let the water run off in the channels when your in a blow.
extravert
20 Jun 2001
Not far from Uwchmynydd, near Bwlchtocyn, just up
I thought about draft excluder, but it is much thinner than that. It's even thinner than the fluffly side of Velcro that I compared it to.
I don't need to change the runners because of leaks. There are already drainage channels and no water has come in yet.
<hr width=100% size=1>One day, I hope to own a real boat.
ean_p
28 Dec 2001
Humber
try Houdini as we've one of their companionway hatches and its fitted with this stuff....also Eagle windows may be able to help.....
Blue_Blazes
25 Dec 2002
Alderney, CI
The Strip you describe sounds like Schlegel (spelling?) pile, it is used in patio doors etc to provide a draught seal and consists of a plastic backing strip which is similar to packing bands, faced with a grey pile material. The plastic strip ususally slides into a "T" shaped groove. If this is the stuff you're talking about, you could try your local double glazing firm and see if they'll let you have some off-cuts.
Bill.
<hr width=100% size=1>One of these days I'll have a boat that WORKS
