i was thinking of making a hatch garage for my snapdragon 747 to fit over the existing hatch and wondered if anyone out there has a mould i could hire or borrow i dont think i am up to making a mould !
If you can't get a mould, you could make it out of ply covered with glass cloth. A few coats of paint sprayed on and it would be indistinguishable from the GRP item, which on my 24 is only screwed on with a few self tappers anyway.
Whatever you use, make it strong enough to walk on and the top surface non-slip.
assuming you are talking about making it in fibreglass a mould is not that hard to make,take the measurements of the house ,allow clearances etc.really its only a mockup of what you need but backwards
if you use hardboard for your faces plastercene in the corners and along the joints a couple of coats of wax and thats about it.try and make all edges rounded as its not easy to lay glass into a tight angle,a good project for the winter
it might be worth looking here www.composites.co.nz/designtips.htm - 14k -
