eastpete
New Member
I have a question Re. The harken 44 (1994 model) electric winch on a Dehler 35 cws. I was able to take off the central screw in ‘pin’ / rod by pulling up on the white push down top with a pair of pliers. This allowed enough grab to loosen the thread. I am now unsure how to screw the central pin back in as the white top is free swivelling and there is nothing to suggest grab for the central pin to screw back in. I managed to screw it in partly by using the whinch handle to push down the white swivel top to disengage the motor and then turn the winch by hand. There is some 3/4mm lift / upward play still however and I am not convinced I have done it correctly. If you havent used this 1994 electric winch before a lot of what I have written won’t make sense - if you have then any advice would be appreciated as to how to tighten it fully.
