Hardwood Dowels
Don't know but you could drill a 8mm hole into a bit of steel and then drift 8/9mm square section of your choosen timber through it with a mallet. Job done.
A "Dowel Plate" is the traditional device
rip timber to approx sq dim + a little then remove 4 corners then 8 corners then chisel a point on one end then drive through the plate with a hammer
PS if you make your own plate after drilling the 3/8 hole slightly counter sink the side you start driving the dowel through.
its worth when a dowel is made to run a tenon saw along the lenght a couple of times to allow any glue to escape rather than end up with comperssed air trapped in the hole you are filling
Dowels will show endgrain and lead water in. I'm not sure what the proper answer is though. Filler, and then cap with a plug that matches the grain?
Whenever I've been tempted to plug a hole with a dowel, the surrounding wood always expands and contracts at a different rate, and the dowel comes loose.
I'm aware of the end grain wicking - so will plug the ends with mahog plugs. The holes will be epoxy glued and therefore the dowel should remain dry I hope. Maybe I can used many plugs banged in ontop of each other, but I suspect there will be more chance of air being trapped. I like Sailorman's idea of running a ridge down the dowel so the epoxy can squidge out and leave no air.
Plugs cut from timber which are normally cut across the grain, show no end grain. so do not wick water into the timber. Dowells may well do that, but why use them, fill the holes with thickened epoxy drive the plugs in, jobs a good'un!
You can buy dowels in standard sizes that are ribbed all round. They are usually about 30mm long and made of beech. If driven in to below the surface you can tidy up with your capping plugs on top.
normally boxwood
Could well be right about that, thinking about it but for the purposes of deep plugging the holes in prep. for capping they would do the job fine, don't you think?
Yep, would be fine as far as I'm concerned, but I would use thickened epoxy myself, never know when those plugs will refuse to go into the hardwood, then what do you do, if they stop proud?
The holes are vertical and my experience is that the epexy will ooze out. The dowels will ensure an airless fix and also there are about 50 holes that need doing, so I reckon a dowel is quicker and less messy - oh, and cheaper than loads of WEST!
Yep, agree, if you can get dowels made a little smaller than the holes, then a good soak in poxy, then fil the last bit with a plug, would do fine for me.
