Poignard
I could turn my Twister in her own length.
She had a RH prop so the way it went was:
Put the tiller port, hold it there with a shockcord loop I had rigged.
Give her a burst of ahead power and the propwash off the tiller starts a tight turn to starboard.
As she turns, put on astern power. Propwalk continues moving the stern to port.
As soon as she is more than 90 degrees to he wind, a burst of ahead power completes the turn.
Free the tiller from the shockcord loop, and off you go.
This is easy provided there is no wind. Even easier if the wind is from ahead when you start the turn.
A wind from astern makes it more difficult, and she might not turn in her own length.
A strong wind from astern makes it impossible in a narrow channel. In that case go astern in a series of curves, kicking her straight when she gets too near the side of the channel.
Or drop a lead weight on a line secured at the bow and weight until she swings to face the wind, then go ahead while retrieving the lead weight.
Finally, prize your white-knuckled fingers off the tiller and bow to the disappointed onlookers.
