Franknstein
Active Member
Hi all
I've got a 16.6ft speedboat with a 115hp outboard on the rear. Also, have a very narrow area at the rear of my property, there is a pavement and concrete area behind the boundary wall, and a wooden gate to access the rear yard. Then two long runners of concrete pavers where the wheels of the trailer will roll.
Till now, I've used concrete pavers and bricks as ramps up the pavement, and a hand winch, with a concrete anchor below ground... and lets just says its a real effort, and kinda makes a weekend away sour as I fight with the wife struggling the boat into the back yard.
My new plan for this season is to use an electric winch, with remote control, so at least I can push at the same time as steering and controlling the boat/trailer into position.
See my attached diagram for the scenario, as well as weights, and then my basic question is, will this winch do the job?
http://www.ebay.co.uk/itm/POWERFUL-...tEquipment_Accessories_SM&hash=item589f5662fe
its 300W, 25A, says it can generate 2,000 LBS / 907kg of force.
UP TO 6,000LBS PULLING CAPACITY FOR ROLLING STOCK
Now, I've been using a hand winch which says 8000LBS. I must say when the rig is on the ramp section its incredibly difficult to winch it, like it feels the hand winch is at its limit.
I dont want to buy and make a custom mounting bracket for the electric winch only to bolt it up and it just makes a whining noise and doesn't pull the boat up!
Any thoughts/help/suggestions appreciated thanks.
