AT present we have a Garmin 45 handheld gps, this is powered by a 5pin plug, assume only 2 pins required for power others are redundant.
We intend to buy a DSC radio in the very near future. The radio will require a gps signal (NMEA format) which is presumably provided via the other 3 pins.
However to achieve this I presume the cable from the 5 pin plug has to split, 2 wires for power and 3 wires for nmea.
Does this arrangement exists as an off the shelf item???
