Niffler
I've been having real problems with my inflatable dinghy that needs two different pressures. It has standard Halkey Roberts valves but the inflatable pump (obviously cheap) has no manometer and the bit you insert into the valve doesn't have a doo doo sort of thing like a bar inside that presses the spring valve in to make it easy to inflate. Is it normal to have a bar thinghy doo doo in the inflater? Any recommendations for a great pump that's easy to use and has a manometer to check pressure?
Thanks.
Thanks.
