Simon F
Hi All,
I want to remove the skeg hung rudder on my Ridgeway marine Pandora 700 so I can recondition it and replace the bushes at the same time, but getting it off is proving difficult. The skeg has a metal casting at the bottom which supports the rudder tube and it appears to be screwed into the skeg from underneath by three screws that I just can't shift. I'm considering drilling them out, but drilling upwards without the bit veering off seems like it would be a tricky task - or I could cut the skeg and screws as close as possible to the bottom which would only shorten it a little, and then reattach the casting in a different way; perhaps through bolting it to a couple os stainless steel plates which could be attached to the skeg. Or there's replacing the skeg, which seems to be held on by some equally unshiftable screws. I'd patch up the rudder in situ, but it's a bit cold for the epoxy to cure etc. Does anyone have any better suggestions?
Simon.
Simon.
