TonyS
We were sailing along, 20 kts of wind behind, through Les Sept Isles, when we tried running the engine for 20 mins to see if we could reach St Peter Port.
Suddenly the engine died as if running out of fuel. We anchored of Perros (first time under sail) and a friend helped us to the marina where we were towed in. The water bleed at the bottom of the primary filter when opened doesn't show anything except bubbles of air are sucked in. I have taken the the hose from the tank off the filter (the one that goes through a shut off valve) I cannot blow through it from either end.
Any suggestions as what to do please. Standard 2003 Bavaria pipework with connections to top of tank.
Tank is half full and fuel seems clean.
Engine will run for 5 mins but increasing revs and it stops.
