Gypsy
A couple of weeks ago there was a discussion (started by BoatMike I think) about gyros for autopilots. I believe he was looking for one with higher accuracy than the Raymarine option. It the ensuing discussion it was noted that there was a difference of opinion as to how the Raymarine Gyro should be installed and where the fluxgate compass should connect.
I have just completed installing a Raymarine Smart Heading Sensor to my boat and what I have discovered may answer some of the questions.
Firstly the Smart Heading Sensor (SHS) is essentially the same as that which was known as the GyroPlus2 but it comes in 2 versions, gyro only for adding to a system which already has a fluxgate compass and a combined gyro and compass version for use with other instruments such as radar MARPA. The gyro is electronic using a special capacitive accelerometer chip, so no moving parts.
My Autopilot is a 6001+ using a 400 course computer (vintage 2002). It has a Raymarine fluxgate compass connected to the computer so I purchased the Smart Heading without the compass. I also have a RL70+ radar and RC530+ chart system of the same vintage.
The instruction book of the SHS has an appendix for installing to systems with both Autopilot and Radar/Chart. The SHS has inputs for a fluxgate compass, SeaTalk and power and outputs a Turn Rate signal to the computer. The book tells you to leave the fluxgate connected to the autopilot but connect Seatalk (and separate power in some situations) to the SHS and connect the Turn Rate to the course computer. For enhanced MARPA operation the book tells you to take the NMEA1 output from the computer to the radar/chart systems. This is a special fast update HDG signal, not the complete suite of NMEA sentences.
Having completed this I was faced with 2 problems.
1) The RED LED which is used to indicate turning to Port was flashing. Reading the book again I see the flashing mode is to indicate that no compass is connected. For the peace of mind I connected the compass temporarily to the SHS and it stopped complaining (flashing) but I returned the compass to the computer. The flashing Red can be ignored for this type of installation.
2)The HDG data on my Chart system was wrong and flicking to another reading by 90deg and more, as was the HDG signal on the data display of my Nav6+ unit which I use at the nav table as a repeater for many NMEA signals (via a Seatalk/NMEA converter). The Radar HDG data was stable.
After some thought and diagnotic work I realised that the SHS system was putting out an erroneous Seatalk HDG signal (248deg) whilst the course computer was putting out the correct HDG on Seatalk and NMEA1. The devices seeing the Seatalk signal had the flicking HDG data whilst the Radar which ignores Seatalk HDG when NMEA is present was quite stable and happy. I had not connected NMEA to the Chart system at this time as I was not sure why it was necessary since the MARPA work is done in the Radar.
It is possible this is where the argument arises about where the fluxgate should be connected as when connected to the SHS and not the computer this would not occur as the SHS would be the only source of the Seatalk HDG data.
Solution. Disconnect Seatalk from the SHS, it does not need it when the fluxgate is not connected to it, and ensure NMEA1 is connected to BOTH Chart and Radar. The SHS puts out 248deg when no compass is connected. These "fixes" were confirmed by the Raymarine engineer in their Australasian support group here who suggests it was an oversight that the manual does not include this instruction for this type of installation.
By the way, I had to have the software updated on my Radar and Chart systems for them to work correctly with the SHS. Raymarine did this for just the cost of the engineers time, half an hour per device.
I have not had the chance to test the effectiveness of the system in difficult conditions yet but all looks good so far.
