Gutted
oakleyb
23 Dec 2004
solent
Decided to remove exhaust manifold on Yanmar 3gmd to paint as it was looking pretty rusty. Took the outer cover off and was met with a carbon filled chamber - answer to why not much water ever seemed to exit the exhaust i guess although she never overheated.
Anyway started manually removing build up only for the screw driver to go through the dividing wall - guess thats a new manifold then ! how much are we talking ? i notice its not listed on the marine power website so i guess its furrharking expensive
One for a Yanmar 3ym20 was £210 last year + VAT. Mine had a cracked weld so the local SS man welded it up for £10.
a new Nanni mixer £75
Eahaust Manifold
Thanks for your replies, i wish it was just the elbow but its actually the entire manifold i need to replace
Make one out of galvanized water pipe and elbows.Then have a flange plate made and welded to the elbow.A sipgot tube will have to be welded to allow for water injection as well.The whole thing can't cost you more than £25 and will last for years.If it works for Bukhs it works for Yanmars.
Yes if you can find a good general welder these things can be repaired/strengthened or copied for less than a new one.
One thing I was happy to see in the spares when I bought this boat was a spare Bukh exhaust elbow.
