[2574]
Does anyone have experience of these new (all bronze) valves? See here: http://www.guidisrl.it/en and click on the link on the right of the screen.
TIA
Rob
TIA
Rob
It scares me that they may be very expensive!!
No doubt Vyv could tell us what this all means in practice.
Interesting. How do we attract Vyv's attention?
TIA
Rob
So far so good, though others have commented that the 'bronze' spec is not ideal and that the balls in the valves will be a different metal.
yes, I looked at the bronze gate valves too but, as you say, the guts is apparently brass so rather defeats the purpose of the bronze fitting. For that reason I think it has to be bronze through hulls and DZR valves and bronze hose tails. The advantage of the Alex valves is they are only bronze and neoprene, no brass. The disadvantage is the size of the fitting which is difficult to accommodate in confined spaces. So, regrettably, DZR it is.
If you're looking to replace through hull + seacock + tail then TrueDesign composite work out cheaper than bronze or dzr. Through hulls can be bedded in Sika or epoxied in. Service kits also available for seacocks. I fitted them last winter. See - http://www.leesan.com/index.asp?m=3&cat1=3&cat2=40&t=Seacocks
PLASTIC!!! What witchcraft is this you speak of????
