Warpa
pretty much the same applies, all products are gelcoat friendly, just need to insert the worb BOAT in the place of navara. Its a post i made a while back just as a rough guide, but the techique is the same i use on the boat except you dont really need to clay (i do when i 1st own a boat, but thats just me being anal)
Its more of a guide to buying decent products that are highly rated, keep the boat/car mint and give massive protection.
Many enjoy looking after what is one of the most expensive purchases you make, your beloved Navara. Some are just work horses, others are your pride and joy, and whether or not you are into cleaning your truck you know it looks and seems to drive better when clean.
This guide is based on hours of practice and a lot of money spent on products using trial and error, and more importantly what works for the Nav.
Recommended tools;
Pressure washer
Dual action polisher (cheap £25 will do until you have around £90 spare)
Wash mitt
Drying towels
This guide will bring the Navara up looking better than it came out of the showroom once you master the art of swirl removing.
1 Rinse you car with the pressure washer, get as much **** of as you can.
2 Get your nice new clay bar out and using the lube that came with it start rubbing all over the panels, you will feel it lift the **** off, continue until the clay glides smoothly over every panel (note the colour of the clay as it picks up the tar)
3 Rinse again and wash, some use a 2 bucket method, one will suffice so long as it’s a proper bucket with grit guard, rinse and dry with your drying towel.
4 Now the fun begins, apply a X of Menzerna cutting polish to your DA (dual action polisher) and doing a small panel at a time work the polish in. I have a mark on mine so when its spinning on speed 6 it rotates about one revolution per second to generate heat so the polish works. Work this over the panel making 5 or 6 passes. This is very time consuming so set a target if you get bored quickly.
5 With most of the swirls gone (your understanding of the machine and what it can do will improve with time) time to use your Menzerna final finish. Yes, you have to do the above all over again!!
Once completed you will already be seeing and feeling the finish on the Nav like you have not seen in a long time.
6 The easy and rewarding part applying the wax, I use Collinite 915 but some prefer the 416, using a sponge wax application tool apply the wax, leave it to cure (run your finger through it, if it comes up clear its cured) buff off with a microfiber cloth.
7 Wheel cleaning, there are plenty of wheel cleaning products out there, but once the wheels are cleaned, seal and wax them as above (by hand this time) and all they ever need is a wash. I use bilberry wheel cleaner, but once they were cleaned, clayed, sealed and waxed they need nothing more than a wash with the last of the water from the bucket after doing the truck.
8Apply a finish or your choice to the tires, I use satin tire gel, others prefer gloss. Job done, stand back and admire your hard work, after completing the above the truck can be left unwashed for around 4 months, then with a quick rinse and wash with a mitt it will look just how you have it now
Last but not least, a quick polish without all the hard work once the nave is back up to its former glory, detailing spray, I use Dodo mist, plenty of others out there thought
List of products that I have tried and tested and know work well on the soft paint of the Navara.
Bilt Hamber clay
http://www.elitecarcare.co.uk/autoclay-soft.php?cPath=79
Maxi Suds shampoo
http://www.cleanyourcar.co.uk/washing-and-drying/chemical-guys-maxi-suds-ii/prod_165.html
Wash mitt of your choice
http://www.cleanyourcar.co.uk/washing-and-drying/wash-mitts-sponges/cat_66.html
Drying towels
http://www.cleanyourcar.co.uk/microfibre-cloths/sonus-der-wunder-drying-towel-pkg/2/prod_84.html
Microfiber cloths
http://www.cleanyourcar.co.uk/microfibre-cloths/eurow-shag-pile-double-density-towels/prod_436.html
http://www.cleanyourcar.co.uk/polishing/polishing-machine/das-6-dual-action-polisher/prod_519.html
Polish, Menzerna cutting polish
http://www.cleanyourcar.co.uk/polis...sive-polish-po85rd-3-02-1-litre/prod_228.html
Finish polish
http://www.cleanyourcar.co.uk/polis.../menzerna-final-finish-po-85rd-/prod_218.html
Collinite wax
http://www.cleanyourcar.co.uk/wax/collinite-915-marque-d-39-elegance/prod_281.html
Wax applicator
http://www.cleanyourcar.co.uk/accessories/meguiars-foam-applicators-pkg/2/prod_177.html
Sonus DAS foam pads (green for the menzerna cutting)
http://www.cleanyourcar.co.uk/polis...ds/sonus-das-green-polishing-pad/prod_58.html
Blue for the Menzerna finish compound
http://www.cleanyourcar.co.uk/polis...us-das-blue-waxing-finishing-pad/prod_59.html
Sealant of your choice
http://www.cleanyourcar.co.uk/sealants/cat_3.html
Quick detailer (top that wax up with a spray)
This is crazy good stuff!
http://www.cleanyourcar.co.uk/wax/dodo-juice/dodo-juice-red-mist-tropical-500ml/prod_541.html
Want to really know more? Google how do use a DA, go to http://www.detailingworld.com, there are guides all over youtube and google
Have fun!
EDIT :mrgreen:
Want to join the foam party? Then if you have a pressure washer all you need is a foam lance and a snow foam :afro:
Foam lance
http://www.cleanyourcar.co.uk/washing-and-drying/foam-lance-various-fittings/prod_371.html
Snow foam
Bilt Hamber seems to be the recommended
http://www.theultimatefinish.co.uk/bilt-hamber/auto-foam-5l.aspx
Valet pro which i also have gives a slightly thicker foam and is a good carrier for car shampoo's
http://www.cleanyourcar.co.uk/washing-and-drying/valet-pro-ph-neutral-snow-foam/prod_500.html
A selection of pics half way down this page
Our own members pics can be found here
artycheer:
http://www.nissan-navara.net/viewtopic.php?f=7&t=9064
And my old bus
Engine detail :thumbright:
Tidying up my spare wheel before i put it back under the truck, it has been there for 5 years. I could have got the inside cleaner and less corosion (bad spelling) but its a spare and not even a 22" like the rest of the truck.
Billbury wheel cleaner applied and left to dwell before rinsing and repeating and agitating with a brush.
Insides i used a bit of fine wire wool as the corrosion was so bad.
A bit of tar to remove with tar remover, then clayed.
Sealed with jetseal 109 inside and out. Not perfect, but acceptible :salute:
Recommended tools;
Pressure washer
Wash mitt
Drying towels
Bilt Hamber clay
Maxi Suds shampoo
Drying towels
Microfiber cloths
Finish polish
Collinite wax
Wax applicator
Have fun!
EDIT :mrgreen:
Foam lance
Snow foam
And my old bus
