Guernsey - Hull epoxy / antifoul
Scarron
22 Jun 2003
We have recently purchased a 1969 Triana 25 which is currently laid up in Marine & General's yard at St Sampsons. She has been out of the water for 2/3 years and so hopefully the hull is nice and dry [in osmosis terms]. Has anyone any recommendations for someone to sand/grit/slurryblast the hull and apply several coats of epoxy plus antifoul [I was wondering about coppercoat?] locally, hence saving the VAT. Bearing in mind I won't be able to supervise or view the prepared bottom - ooer missus.
DepSol
6 Oct 2001
Guernsey
There is a guy locally who can sand blast the hull and I have just called Jeff for you and he can epoxy it for you but will be in about two weeks time which gives you time to have it stripped back.
If you need a hand with supervision of the works sen me a pm as I am down that way every week and know the people who do the jobs I dont mind helping you out. Also can give you the name and numbers of people for lifting etc.
I take it you have seen the boat etc. Do you need a surveyor?
<hr width=100% size=1>Dom
<A target="_blank" HREF=http://www.soltron.co.uk>the website</A>
Scarron
22 Jun 2003
Dom
Thanks very much for your offer of help/local info, much appreciated. I knew the forum would come up trumps! I have sent you a P.M.
Paul
gonfishing
21 Jan 2003
Hi Paul
Don't expect anything to be done at the weekend though, the place is is Shut!!!!!!
Julian
