Guard rail insulation
Vara
20 Feb 2004
Canterbury/Dover
AFAIK from an electrical point of view the only reason to insulate guard lines was in the good old days of RDF to eliminate/reduce quadrantal error. (Didn't make any difference, the only good thing about RDF was that you could listen to the Archers while pretending to navigate).
The little plastic bushes in stanchions are to protect against chafing and therefore a good idea as long as they are a loose fit.
Vara
20 Feb 2004
Canterbury/Dover
Don't really know, I suppose in theory if you connected all the guard rails and standing rigging while insulating the mast it would provide some sort of faraday cage.
In a thunder storm the safest place to be is in a car.(bit like the sea sickness cure..........sit under a tree not really practical or helpful).
Salty John
6 Sep 2004
UK
www.saltyjohn.co.uk
As long as the mast is grounded the 'cone of protection' or 'Lightning-Protective Zone' afforded by the mast and rig would encompass the guard rails, so no extra benefit from that point of view. You could theoretically make the interior of the boat into a Faraday cage by interconnecting all the peripheral bits of metal, including the guard rails, but I don't know how effective it would be!
bigwow
26 Feb 2006
Might be a thunder storm this week-end, wonder if the car will fit on the deck?
/forums/images/graemlins/laugh.gif
graham
This one would...
Pete7
11 Aug 2004
Gosport
Was this the reason that yachts had the last couple of inches of the guard rails secured with thin rope normally at the pushpit? and is it still required ?
graham
I think securing the guardwires with lanyards is to allow you to cut them quickly if you need to haul someone back aboard.
VicS
13 Jul 2002
[/ QUOTE ] Thats true but it did also introducie a break in the loop that was, we were told, necessary if using RDF
(PS any body know of a use for a Seafix .... proposed as "the most useless piece of marine equipment invented ever", elsewhere on the forums.
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
There is no way you can turn guard rails or rigging into anything approaching a faraday cage. Forget it!
That's interesting;- I've read just the opposite on many occasions.
Who is right? (I'm not prepared to test either theory!)
rogerthebodger
3 Nov 2001
Man over board locator. Using a VHF radio microphone transmitter potted in a small plastic box attached to the MOB.
VicS
13 Jul 2002
[/ QUOTE ] Nice idea but Seafix covers 200 - 400 kHz, hardly VHF. Radio mikes work at around 174MHz or even UHF. I suppose it would not be impossible to build a transmitter to work within that frequency range though. Since the Seafix can detect an unmodulated signal modulation would not even be necessary. Trouble is the MOB might have to take a big aerial mast with him!
VicS
13 Jul 2002
Nice little compass though innit?
[/ QUOTE ] It is, and it used to be possible to get a handle to fit to convert them into hand bearing compasses. At least it was for the earlir ones which had a Sestrel compass. I've got a handle for a Sestrel but sadly the later type of compass.
