BabaYaga
I am changing the cutless bearing in my long keeled GRP boat and would be grateful for some advice.
The present bearing (brass shell, 100mm long) was quite a tight fit in the GRP stern tube, requiring a large hammer to install 16 years ago and subsequently now very difficult to remove.
To make replacement easier in the future, I am planning to slightly widen the stern tube to give the bearing a somewhat looser fit. To hold it in place and stop it from rotating I will instal a grub screw or two.
My questions:
Does this sound like a good idea?
Do I simply drill a hole and tap a thread through the GRP deadwood into the stern tube (about where the blue dot is in the photo?)
Should I use two grub screws, one on either side?
Would M5 or M6 be a suitable screw size for the 38mm diameter bearing (25mm shaft)?
Anything else to be aware of?
My questions:
