Cardo
Good afternoon, fellow sea gypsies
Some of you may be aware we've been suffering from suspected water ingress for the last few weeks. This morning we discovered this is coming from a small crack in the GRP, near one of the corners of the moulded grounding plate recess. Apparently, it's a known fault where cracks can form as a result of stresses on the keel and associated grounding plate.
To begin with, I'm going to attempt to patch the crack on the inside using some two part epoxy stuff that I got to seal a hole on the engine's exhaust manifold. Hopefully this will stop any more water getting in, at least in the short term.
In the medium term, I'm wondering if there is anywhere decent on a Peleponnese circuit (We're on the south of Cefalonia, about to jump to Zakinthos and onwards) where we might be able to haul out the boat and get the hull fixed properly? Ideally, somewhere that doesn't gouge you to lift the boat, and where a good GRP man is available.
Any suggestions, as always, gratefully appreciated.
