SimonD
The ring anodes on my VP 290 DP-E drives are eroding rather too quickly. The last pair disappeared completely in nine months resulting in some pitting on the stainless steel duo props. I replaced the anodes five weeks ago and have not left the boat with the mains cable connected. I had a look at them yesterday and they are already showing signs of corrosion. Given this high rate of erosion, I suspect there is some electrolytic corrosion at work.
I've tested the galvanic isolator and it seems fine. Next step is to check for stray current in the bilge. The bilge pump switch doesn't work and I suspect it's failed partly closed allowing some current to pass (reed switches can do this). I'll also check the grounding of the legs. I assume that if the legs have good continuity to ground, this effectively stops electrolysis. This gives rise to my question: assuming the legs are properly grounded to the battery negative, does it help prevent electrolytic corrosion if the shorepower lead is connected, i.e. is it better to have the boat's ground connected to the marina supply earth?
