pappaecho
In November last year I fitted a 15 watt solar panel to my new boat, and it worked fine. In early march, the battery banks was losing ground in terms of voltage. On investigation about 18 volts (unloaded) was coming from the solar panel but only about 9 volts was appearing at the battery connection. The Marine Water proof plug and socket was the fault.
On another solar panel installation done two years ago exactly the same problem has occurred. In April sunshine 20 volts at the panel but only 12.4 volts via the plug and socket system. - remove the plug and socket and replace with terminal block and the system works fine.
These plugs and sockets are sold by most chandlers, and they seem to be OK for high wattage connection, but now in two cases, the relatively low wattage 12-15 watts, seems to be affected by high resistance due to dulling of the brass connector pins and sockets.
Anyone know of either a good make of plugs/sockets for this application or possibly gold plated plugs and sockets, suitable for solar panels
