Steve C Cronin
N/A
Which greek weather forecast do you trust the most?
Poseidon, Meteo Greece, Grib, Windfinder or wtw?
http://poseidon.hcmr.gr is as good as any you just got to read between the lines .
www.bluewatersailorcroatia.webs.com
Have to agree. This season we have been monitoring Poseidon, Meteo.gr, Windfinder and the Turkish one. Mostly Poseidon has been the more accurate but none could be described as spot on. Today for Samos Sea Navtex says 6-7, Poseidon says 4-5 for where we are, meteo says 6. Have just sailed across Leros to Lipsi in a 3-4.
Zygrib gave 3 to 4 on the 4th (data set for the 3rd). We found it the most useable - down loading an 8 day forecast which enabled you to see what was coming to plan. We then also used Poseidon to confirm the more immediate forecast - but beware of them not updating the forecasts!
However things like wind finder I understand just use the Grib info and will give you exactly what the Zygrib gives you. Zygrib has the added advantage that you down load the file and it is then available even when out of data contact.
Mostly this ... http://212.175.180.126/DTS/sea.php but given the localisation of the weather none can be 'trusted'
...So, use http://212.175.180.126/DTS/sea.php but keep an eye on the GFS. Forget the rest.
I was playing with the Turkish website this year and using the 'forecast for a point' and 'cruise planning' functions. In the Ionian, 'forecast for a point' was as good as any of the others, ie wrong some of the time; however cruise planning proved surprisingly accurate even after 48 hrs without update. If you leave your browser open after creating a route you can track the weather along the way.
For the overall picture we use the University of Athens forecast http://forecast.uoa.gr daily.
You need to select High Resolution in Forecast, then Athens (or Greece) as the area, and then Sea Surface wind in the last field.
I believe uoa modelling had a lot of funding to improve it's forecasting for the 2004 Olympics. It may not be as good for elsewhere in Greece but I find it great for the Athens & Saronic areas.
I'd agree with Melody, that the most accurate I find to be the Athens uni site.
Turkish weather might be OK, but for the presentation, the maps are small and confusing. Posiedon is generally mediocre.
Though Frank strongly disapproves I use the NOAA data and do my own extrapolation - which I've found far the most reliable.
