28 Jul 2006 #1 K KAM Well-Known Member Joined 6 Jun 2005 Messages 1,356 Visit site My 72 works fine with DSC radio but I can not get it to talk to the tillerpilot. Wiring is correct but NAV will not lock. Have tried changing NMEA settings. Has anyone got this combination to work?
2 Aug 2006 #2 hightech Well-Known Member Joined 21 Nov 2004 Messages 537 Location Portsmouth, UK www.sargentmarine.com Should work fine, have you got the blue wire and black Ov wire from the GPS connected? Try setting output up for NMEA0183 and the lowest version. Then make sure you have an active waypoint and away you should go!
