jfm
Why do thrusters need to be electrically powered,,,,I am a suporter of hydraulic pumps/drives, proved over many years in industrial/agricultural and other industries to be very reliable, needing only a little operator maintenance........I will also say, in my opinion boat propellors thrashing around in water ,,are as much use as aircraft propellors, in todays world, we just need to develope existing propulsion systems for motor or should I say powered boats,,,,,,,,,another point,,,,,water jets are more economic,safer also low maintenance than large metal lumps that are needed to turn shafts and propellors........
I'm confused. This discussion is the same whether the b/thruster is electric or hydraulic. Sure, plenty of people have referred to electric because they are common, but the basic discussion on a b/thruster as an a/pilot remains the same
As regards water jets, they still have a shaft, propeller/impeller and a big engine to turn the shaft. Or are you thinking of something else like diesel fired gas turbine engines to drive the jet (you'd still have the shaft and impeller even then, and certainly not low maintenance)
