GrowingLad
Just thought I'd post this up as I had a bit of a job trying to find the information required on the web, so if I put a post up here other peeps on the interweeb might find the below helpful.
I've got a separate GPS receiver that connects to my laptop via a USB connection to supply GPS data to my Garmin chart plotting software.
I've recently bought a DSC VHF radio that required a GPS input.
Now I was using Franson GPSgate to translate the GPS signal from the receiver to the Garmin software.
I configured the Franson GPSgate to also have the serial RS-232 as an output. I configured it with a speed of 4800 baud. I also right clicked on Mycomputer to management / Device Management / Ports (COM & LPT) right clicked on properties of COM1 and checked the baud rate.
I then had a D9 connector (if you can get hold of a Blue Cisco console cable it makes the job a bit easier)
I used a continuity tester to find the cables for pins 3 and 5.
My radio is a ICOM 411 with a kind of coaxial cable.
The outer conductor is NMEA - (common)
The inner conductor is NMEA +
You need to connect Pin 3 of the D9 serial RS-232 to NMEA + (inner cable of the radio)
and Pin 5 of the D9 serial RS-232 to NMEA - (outer cable of the radio).
If your machine doesn't have a serial RS-232 you can get a USB to Serial converter for around 10-20 quid. I've used these a lot in my job and have very rarely had a problem.
Had my laptop/GPS, VHF radio and 12v car battery out on the balcony last night and got it all running sweetly. I had read somewhere to use pin 2 instead of pin 3 but this doesn't seem correct to me as mine was working with pin 3 and 5.
I hope someone finds the above useful.
GL.
GL.
