JumbleDuck
I have a Cobra radio which has for a few years been happily taking a GPS position from the NMEA output of my Matsutec HP-33A GPS/AIS. It took a while to get that working, as it turned out that of the outputs available
only REM1 was acceptable to the radio.Last year the Matsutec failed, so I bought a new one through Amazon. Unfortunately the new one has a much narrower range of NMEA outputs (I suspect that I have been sold an older model) and none of them
is accepted by the radio. The only sentences in REM1 which are not in any of the current outputs (as 4800 baud) are DTM, RMB and RMC and which are, respectively, "GPS Datum In Use", "Recommended Minimum Navigation Information" and "Recommended Minimum Specific GNSS Data". Of those, only RMC includes the receiver latitude and longitude (see https://www.gpsinformation.org/dale/nmea.htm#RMC) so it looks to me as if that's what the radio wants, rather than a nice simple GLL (https://www.gpsinformation.org/dale/nmea.htm#GLL).
I have a temporary fix. The old HP-33A had two flaws: it turned itself on (which I can live with) and it lost fix constantly, but the latter seems fixed, for now, by using the GPS antenna which came with the new one. However, I'm not confident that it will make it through the summer, so, to cut a long story short ...
Can anyone suggest or recommend a stand-alone GPS receiver which will transmit NMEA-0183 RMC sentences, or something else acceptable to a Cobra radio, at 4800 baud?
AP Output: AAM, ABP, BOD, BWC, GLL, VTG, XTE, ZDA (4800 baud)
GPS Output: GGA, GSA, GSV, VTG (4800 baud)
AIS Output: VDM, VDO, GGA, GSA, GSV, GSV, VTG, RMC, GLL (38400 baud)
