dje67
Got myself a 12.9" iPad for use at home, but now want to make use of it as a plotter on board. Screen size is amazing! Obviously, I'd want to get GPS into the iPad and I'd also like to get AIS (and possibly some NMEA 0183 info, though not a priority). I use the Navionics app. I've no NMEA 2000 hardware onboard.
I also use a Standard Horizon plotter and would to have an additional, direct-wired NMEA 0183 AIS feed to the plotter from the AIS unit I get.
There seems to be a couple of GPS units that can connect to the iPad using Wifi or bluetooth. If I have separate GPS and AIS units then the iPad can only connect to one of them. So, I'm hoping that there's a single module out there that can provide the iPad with both GPS and AIS (+ poss NMEA) through a single Wifi (or bluetooth) connection.
Has anyone else been down this road? What did you use?
There are many Wifi-enabled AIS modules out there, many of which have a GPS receiver. But it is not clear whether the GPS info will feed to the iPad (and work!) or whether it is only the AIS info that will get sent.
The (few) GPS modules that I've found are:
Garmin GLO 2 GPS and GLONASS Receiver £70
Bad Elf - various models around £150
Neither do AIS, though. Don't think they will allow the direct-wire to my plotter either.
There's Quark A-026 module that does AIS (and NMEA) with a GPS input, but I'm not sure if the GPS data gets sent and if it will provide instantaneous, continuous GPS data that the iPad can use.
Thoughts?
Thoughts?
