oldharry
By general request, I have copied this important post across from the Studland sticky thread:
Few of us are aware that the ramifications of the Marine Coastal and Access Act (MCAA2009) carries also the governments intention to take much greater control of our coastal waters.
In addition to the MCZ process currently under way, the Act calls for a Marine Plan which will effectively bring our waters under the same level of control and regulation as we 'enjoy' ashore.
The Marine Plan will be developed and administered by MMO. MMO has created 10 regions, each of which will have its own plan.
What does this mean? The project is only just getting under way, but an earlier press release spoke of it 'affecting all water users, right through to kite-surfers'
The bottom line is that the infrastructure is now falling in to place to regulate leisure boating. With that comes the possibility of licensing and permits, classification, taxation and other limitation on the freedom we enjoy at present when we go to sea.
MMO yesterday (1st August) released news they were starting work on the Marine Plan for the South Coast, an area defined as Dover to the Dart. I know little more about it than what is in the release, and the little bit of background outlined above.
Press release here, and it is worth following the links in the menu on top left. At present it doesnt sound as if it will impinge much, but as I have said before, if you own a 'free' mooring, before long you will have to apply for permission to keep it. The thin end of the wedge?
http://www.marinemanagement.org.uk/news/press/120801.htm
The first stage is identifying 'key areas' within the region, and the activities that take place in them.
