Uisteach
There's been some discussion that cuts across this question so I thought some might find interesting an e-mail I've recieved from a person who runs Amateur Radio Licence courses.
"The answer to your question [which is best for use on a boat]relies on want you want the SSB for.
An amateur radio licence permits you to operate on the amateur frequencies
and allows you to communicate with other radio amateurs. You can operate
your ham station from your home or from your yacht. But you can only
talk/communcate with fellow radio amateurs. To obtain a ham licence here in
the UK takes about 16 to 20 weeks and requires a bit of studying.
A marine licence (GMDSS Long Range Certificate) allows you to
operate on the marine SSB frequencies where you can talk to fellow
yachtsmen, make and recieve telephone calls via coast radio stations. You
are only permitted to operate your marine SSB whilst you are onboard your
yacht.
To obtain the GMDSS Long Range Certifictae takes 4 days and is a lot easier
then obtaining a amateur licence.
If you want to talk to radio amateurs and transmit on the marine frequencies
then you require both a GMDSS Long Range Certificate and an amateur radio
licence, you cannot use one licence to do both."
yacht.
