AndyL
I need to repair a cockpit grating but am severely allergic to epoxy after years of osmosis repair work. So I need a non-epoxy based waterproof adhesive. I suppose I could use Sika 291?
I have just done mine with Polyurethane Glue. This cures in the presence of moisture, so dampen each side slightly. It "Foams up" and expands to fill gaps, and is waterproof.
Gorrilla is one trade name, but beware Gorilla also now sell PVA glue, which is completely different.
I have used resorcinol adhesive for decades, which is a dark purple resin (consistency like treacle) and a powder hardener, for anything which is liable to get wet, even when the part is underwater. I believe that is the same type of adhesive that is used to make marine ply. Trade name was (is?) Cascophen but this is no longer available locally and so I have found an identical product from Germany.
One major advantage in my country is that is totally resistant to UV rays and it also does not fail or go soft, like epoxy does sometimes, when the wood becomes hot in the sunshine. Also excellent for making laminated tillers, beams, etc.
Thanks, I will try Cascamite.
Cascophen is suitable and is still available.Oily timbers, such as teak, present problems with the "oils" inhibiting a satisfactory bond.
Degreasing is normally required; this can be achieved by wiping the surface with washing up liquid.Sanding can also remove surface grease, but if the adhesive is not applied shortly afterwards there are likely to be problems of case hardening where the oils have surfaced again.
Don't. Read the data sheet.
www.hallmarkfraulo.co.uk/assets/pdf/Wood_Glue_Cascamite_TDS_HF.pdf
What is the brand name of this German adhesive, please?I have used resorcinol adhesive for decades, which is a dark purple resin (consistency like treacle) and a powder hardener, for anything which is liable to get wet, even when the part is underwater. I believe that is the same type of adhesive that is used to make marine ply. Trade name was (is?) Cascophen but this is no longer available locally and so I have found an identical product from Germany.
