bryandowdey
I have an Ardic 04-D diesel air heater to heat my 23 year old Sealine motor boat. I think it's the original unit. After revamping it it works perfectly well but only in hot weather and never in cold!
The problem seems to lie with the Glow Plug which I think is not getting hot enough.
Does anyone know a source of glow plugs for small diesel heaters? This one is 12V, has a spiral heater wire within a metal cylinder with a ring of small holes drilled around the lower part of the cylinder. The top has a hexagonal head and a screw thead to fix into the heater chamber.
Any help would be welcolm. The cold weather is coming and that is when the diesel doesn't fire although the glow plug glows.
