srm
Yanmar 2GM starter motor was making intermittent mechanical graunching sounds. These soon grew worse and stopped engine from turning under starting loads, but spun happily with de-compression leavers down.
Removed starter motor and found bearing bush at flywheel end worn and pushed half way out. All it needs is a new bush, so decided to change front end bearing at same time. Sounds simple? Read on.
Phoned Yanmar main dealer and spares stockist on south coast. Initial response – “everyone throws faulty starters away”. When I said all I needed was a little bronze bush and did not live in the affluence belt he offered to see if Yanmar listed starter parts. He found the flywheel end casting, but at a cost greater than a complete starter motor “they have never sold one”. He also found the front end cover listed, which presumably included the front end bushing at £17.50 but none in stock in Europe, “needs to be ordered from Japan”.
A firm specialising in refurbished motors and alternators offered a rebuilt starter, but declined to supply parts.
Am trying locally, but does anyone know a source for a soft bronze bearing bush. Shaft diameter 12.5mm, x 16mm outside dia.x 15mm length? As long as it costs less than £220 + p&p which is a new starter motor.
Globalisation? - there was a lot to be said for old fashioned “make do and mend”.
