philipdawsonladds
Does anyone have Glendinning controls that could advise? New boat to me with controls installed 2008. All fine during the sea trials but once off loaded from transport discovered that the STBD engine would not stop. Suspect a solenoid has failed. The engineer also managed to install the props the wrong way around so the controls worked backwards. He re-calibrated the control boxes and all seemed fine. Backwards, forwards, left and right on both engines. In the last few days though a problem has developed, unfortunately intermittent, On power up the STBD throttle won't move out of neutral. If I turn the ignition key off then on again it seems to clear and works normally. However, it is also reverting to neutral while underway, requiring the same ignition key fix. Sometimes this hasn't worked though. I'm trying to figure out what or where the problem might be. Seems unlikely that the control box has suddenly failed but perhaps the re-calibration has stirred something up. Ideas???
