NickHarley
I've got a solid wood rudder that was encapsulated in glass/epoxy... the sheathing had cracked & delaminated after 10 years letting in water, so I've stripped it back to bare wood. Condition seems OK now dried out & surface cleaned up. See attached for 'before' pic.
I think I'm going to encapsulate it again... something along lines of :-
1. Seal with a really thin coat of epoxy to soak into wood & bind
2. Next epoxy layer (after scrub with acetone?) with a thinish glass cloth (c. 150g/m) so that its still transparent (I like the 'varnished wood' look).
3. Primer/antifoul below waterline & varnish top half to protect against UV. (several layers).
Obviously I'm happy to be told in general terms if there are problems with this plan, but I have two specific questions -
1) How should I physically lay the cloth... by that I mean can I lay rudder on its side & do one side at a time (with overlap on leading edge?), or should I try pointing leading edge up and lay one piece of cloth over both sides at once. I've seen people hang them from ceilings etc on google... but not convinced its feasible on one this size (almost 6 foot).
2) Should I add extra (heavier) cloth below waterline for strength/impact resistance etc.?
Any advice would be appreciated! Many thanks.
