rhumlady
When glassing in bulkheads using West epoxy and 360gm cloth, how many layers would be advised? I am quite able to get a 1 to 1 ratio glass to resin.
I would suggest not thicker than the bulkhead thickness, possibly down to half thickness on each side of the bulkhead. Mind you this all depends on the reason for the bulkhead : watertight and structural to a simple partition type from one area to another.When glassing in bulkheads using West epoxy and 360gm cloth, how many layers would be advised? I am quite able to get a 1 to 1 ratio glass to resin.
Personally I wouldn't use West Systems epoxy for that job - it's too viscous to wet-out mat throughly (or to penetrate plywood to any depth) - indeed I don't know why people rave about it.
QUOTE]
I have just had occasion to redo two lipped cupboard doors (12 X 6 teak strip round all edges). One door allowed its lips to be separated easily and indeed they were reusable. The lips from the other had to be destroyed to separate them from the door panel.
West System was used for the first, a bog standard B&Q grab adhesive for the second.
Conclusions?
The bulkheads are marine ply. I was not aware of the 45 degree bit as I assumed strength would come from the direction of the fibres and at 45 degrees the strength would be reduced. I have the epoxy and am happy using it. I don't want to go over to polyester again.
QUOTE]
Conclusions?
Using epoxy resin alone as a glue is not a good idea, epoxy resin alone is very brittle so any movement can break the bond, particularly if the layer of resin is only thin.
Adding some Micro-Fibres to the resin and leaving the joint material at least 1 mm thick will result in a very strong bond, making removal all but impossible without breakage.
Hope this helps.
Good luck.![]()
