superheat6k
Last question this morning.
The disused holding tank on my boat still has the outlet to underwater plumbed to the discharge pump, with a large 2" and very seized ball valve in the most awkward position known to man, indeed a surveyor has yet to find it.
So in view of its seized open condition, ridiculous position and current redundancy I was minded to remove it and glass over the opening inside and out.
Except someone has already glassed over from the outside only !
At first I thought I was losing the plot with my inability to locate to outlet skin fitting until I noticed a very slight depression I the approximate place it should have been.
Closer inspection on the inside shows whoever did this modification has surrounded the seacock lower area and presumably what remains of the internal part of the skin fitting with some form of brown plastic resin, rather doing the job properly and removing the entire fitting.
So do I return my prior state of blissful ignorance, or do I get various cutting tools out and complete this bodge job properly, bearing in mind the working location is horrible ?
I do wonder if the cowboy who did this still roams the wilds of Jersey practising mayhem to others' boats where my boat spent its entire former life !
