southerncross
New Member
I know that Actisense doesn't support thermocouple type sensors for capturing EGT, and that this is simply a limitation of the sensor type. Thermocouple type EGT sensors output a voltage, whereas the EMU-1 gauge inputs want to read current through a resistor (like most traditional gauge/sender).
However, I found this EGT sensor which is resistive based: Exhaust Temperature Sender
Has anyone ever tried using this sensor with the Actisense EMU-1? Based on my read of the specs, it seems like it should work.
-SC
-SC
