Foxy
Im remounting my genoa tracks which are mounted with woodscrews into the sheer planks. Im considering replacing the actual tracks as I think the newer designs are probably easier to fit and seal. Basically my current set up is a flat track (schaefer) with a 'n' - shaped plastic spacer underneath. Its survived 35 years but looks like the new tracks are all one piece.
Three questions
first is do you think old 1 1/4" cars will fit on 32mm track (i can test if i can find some).
Second - any thoughts about the old two part track?
Third, who make the best track?
Boat is heavy long keel cruiser. head sail area 50sqm - like to over engineer if poss, looking at 32 mm track and 8mm screw fixing. W
ill try to bolt through anywhere i can access.
cheers in advance
Pat
Three questions
cheers in advance
Pat
