Genoa sheet carrs position?
benw
6 May 2008
Baston Lincs, Boat Royal Harwich YC
Having experimented in light medium and heavy airs with the genoa track carrs can any one offer the definitive? We have an overlap[ping furling genoa which is a pig when furled to set. I know this is one of the drawbacks of the furling genoa however feel i should still be able to get best advantage tweaking the carrs.
I believe it should be fwd for light and aft for heavy. I stand back for the barrage of advice...
Many thanks,
Ben
Many thanks,
Ben
I've never heard that rule of thumb before.
To get something that isn't just spouting, "Illustrated Sail & Rig Tuning" gives the following:
*Start with the car such that the Genoa sheet points at the mid point of the luff
*Then try getting the sail to luff
*If the top luffs first, move the car forwards
*If the bottom luffs first, move the car backwards
*If it luffs along the whole length at the same time, you are doing it right
In heavy airs you usually want a flatter sail (assuming you are beating), but you would control that with Genoa sheet not with the car.
That's what I try to do, it's based on that book, so if it's wrong then I'm doing it wrong :)
Jamie
I have read (and put into practice) the advice that you move the cars forward in lighter airs - to give the sail a fuller shape. Bringing the cars back flattens the sail (tightens the foot rather than the leech). When partly furled the cars need to go forward too.
Jamie
+1
Buy the book...
