BobE
My Genoa roller reefing failed on Monday en route to Cherbourg. The sail simply fell down when the top swivel came apart due to, (I think) the upper circlip thingy failing .
So now it’s being rebuilt.
But any comments on setup and/or tensions will be appreciated.
It seems to me that one should first set the length of the wire forestay to get a suitable mast rake. At a reasonable backstay tension (?? Wot’s reasonable??) (BTW forstay, backstay and shrouds are 7mm wire the babystay is 5 mm)
Then mount the foils ensuring that the top one can still rotate on the swage at the mast head when the lowest is clamped into the drum..
At this point I get even more befuddled than normal…
Why did the circlip fail? Had I overloaded it ? When sailing without all this gubbins we used to really pull up on the genoa halyard ‘till it was bar tight..
Now with the foil system I guess the luff sag is taken out by the foil and forestay tension and the halyard just tightens the luff tape to flatten the front of the sail and give a smaller angle of attack and therefore better pointing….
Am I right… Have I been over tensioning the halyard? Should I really whack up the backstay before adjusting the flow with the halyard…..
Help!!!!
Cheers Bob E….
/forums/images/graemlins/confused.gif
Help!!!!
Cheers Bob E….
