snappie
New Member
Hi guys,
Working on stripping back the paint on my snapdragon today.
Working inside the cabin, and on the cabin roof /sides (above the waterline).
For the snapdradgon, it looks like the sides / roof were moulded separately and connected to the hull moulding.
My question is as follows:
It looks like there is a lot of little osmosis blisters (maybe an eighth of a centimetre, on avg) but there are a lot of them.
The PO had sprayed on a heavy non-slip paint, over a thick white undercoat on the cabin sides / roof. I didn't see the blisters below this. When I'm sanding this back (Random Orbit sander, 40 grit), I can see where the sander is smoothing these out.
Is this a problem? Do I need do something else than sand back to a smooth gelcoat, and then paint (for the first time in a few years).
Also, on the hull moulding, it looks like there is just paint over the fibreglass. I'm a bit nervous sanding this back with the random orbit, as it don't want to damage the glass. its the same awful mixture of non slip paint and the white undercoat (albeit not as thick).
