PaulMcC
Hi All,
In preparation for warmer weather I'm planning to improve the insulation of my coldbox. A previous owned has installed a fridge cooling panel, then taken it out again and filled the gaps he created with expanding foam so the whole thing is a bit of a mess and it's finally reached the top of the jobs list!
Having had a good look around the space available, I think I will be adding insulation both inside and outside the existing plastic box and then doing something to reline the inside afterwards. Is there any particular type of gelcoat or flowcoat that is recommended for the inside of coolboxes and good for applying on vertical surfaces? (Foodsafe, low in volatiles, won't make the cheese taste funny, etc.)
Thanks!
Thanks!
