laika
Every so often I bite off a little more than I can chew. Despite having read 3 different books on the subject I feel I still need to ask questions...
I'm trying to fill a hole in the cockpit where some speakers used to be. I'm a dab hand with gelcoat filler, but serious stuff is new to me. The previous owner had stuck circles of acrylic over the holes, but seeing as the headlining is down I thought I'd have a go at filling them.
I've ground down a bevelled edge on the inside (not 12:1 because there's not space, but it's not too bad), lightly sanded outside, acetoned everything, got a couple of bits of acrylic covered in releasing wax and screwed them outside the 'oles so I'm ready to go. My plan is paint a couple of layers of gelcoat on the wax (from the inside), then laminate csm and cloth behind it, then remove the acrylic and tidy up the outside. But...
* Do I need to add wax in styrene to the first (outer) coat of gelcoat (my primary book doesn't mention this), will the screwed down acrylic behind it allow it to harden without, or should I put gelcoat with wax in styrene over the outer layer later?
* How long between gelcoat coats (ie how hard for the first coat before applying the second)? Presumably this means 2 lots of mixing
* I'm aware that a little tackyness helps with the chemical bonding. If I don't get the whole job done in one day, which bit should I leave over night (ie if it's the end of the day, do I leave it at the second layer of gelcoat or do I do the first layers of resin and glass).
Sorry to ask what research should tell me: I've asked a couple of people who've given me two different methods and completely different to my books, so trying to crowdsource this
