gel coat repair
neilsan
15 Oct 2002
Hi , a friend in Spain has lifted his boat out on the dry for the next six months.He has ground of the gel coat to dry out the hull and plans to eventually finish off with Epoxy Tar.Does he have to coat with a few coats of Epoxy or can he put the Epoxy tar straight onto the ground matting. Any info greatly received
Talbot
23 Aug 2003
Brighton, UK
Epoxy tar is really designed to go over the gel coat as an additional layer, but really you need to talk to the manufacturer of the product to get the correct answer.
oldsaltoz
4 Jul 2001
Australia, East coast.
G'day Neilsan,
If the gel-coat has been ground off, then presumably it will need fairing, this would be an ideal time to add the 3 layers of epoxy, and perhaps consider one layer of glass prior to the 3 layers.
You say he plans to coat it with epoxy tar, could this be Tar-epoxy, banned in most countries as its a carcinogenic.
I would advise him to read the can, get a copy of the 'safety data sheet' and check the manufacturers spec's prior to committing to this action.
Avagoodweekend......
<hr width=100% size=1> Old Salt Oz /forums/images/icons/cool.gif Growing old is unavoidable. However, growing up is still optional.
