Gearstick
robind
23 Jul 2003
sussex
Have a word with the skipper he will show you everything.
regards
Rob
<hr width=100% size=1><A target="_blank" HREF=http://www.rejuvanu.com>RejuVanu</A>
hlb
RIP
Any Pub Lancashire or Wales
Either that or another Happy.../forums/images/icons/laugh.gif
<hr width=100% size=1> <font color=blue>No one can force me to come here.<font color=red> I'm a volunteer!!.<font color=blue>
Haydn
Renegade_Master
27 Jan 2003
Spain
saw a boat ad today and it said two .....whatever engines.....with Trolling Valves?
whats that then?
<hr width=100% size=1><A target="_blank" HREF=http://www.suncoastmarine.co.uk>Sun Coast Sea School & Charter</A>
oldgit
6 Nov 2001
Medway
Re: Dipstick
As an aknolleddged xprt on this subject,It is some sort of valve in the engine fiel line thingy that sort of strangles the flow of fuel stuff.
so less fuel less power less speed simple innit.
<hr width=100% size=1>If it aint broke fix it till it is.
Renegade_Master
27 Jan 2003
Spain
Re: trolling valves
yes yes yes.... no no........ not that, I've seen that, this is trolling valves...........
hlb
RIP
Re: trolling valves
Maybe it's Becks and Poshes gear stick!!
Haydn
Renegade_Master
27 Jan 2003
Spain
Re: Dipstick
for going slow up rivers an stuff........ err Fred. (sound like Barney rubble now)
kindredspirit
28 Nov 2002
Boat: Kilrush.
www.begleys.com
Oh! That's easy. On a boat it's near the brake pedal.
<hr width=100% size=1><A target="_blank" HREF=http://www.begleys.com/kevin/weather.htm>Weather & other useful links for Irish waters.</A>
BrendanS
11 Jun 2002
Tesla in Space
Re: trolling valves
you might have seen it, but you didn't read it. Kim gives an explanation of what trolling valves are in that thread! /forums/images/icons/laugh.gif
<hr width=100% size=1>There is no such thing as "fun for the whole family."
jimi
19 Dec 2001
St Neots
Re: trolling valves
Always thought it was "trawling" valves .. anyroads ...David. have you managed to do the jigsaw that Posh gave you in that bowl at breakfast yet?
<hr width=100% size=1>.. whit way roon should it be again ..
BrendanS
11 Jun 2002
Tesla in Space
Re: trolling valves
definitely trolling,
I've taken the cornflakes off David, and put them back in the packet. He can play jigsaws with them again tomorrow
Renegade_Master
27 Jan 2003
Spain
Re: trolling valves
was such a long load of posts on that thread I got bored and missed the bit about valve trolling.
So Brendan "I read and understand everything" Spillane is Oldgit right then?
adarcy
31 Aug 2001
Re: Oldgit right?
Regret no
I do not believe trolling valves work as oldgit says by reducing fuel flow - they would just stall as they are only of any use if the in-gear idle speed is too fast.
They work on large hydaulic gearboxes (often in fishing boats) by bleeding off some of the hydraulic pressure which clamps the clutch plates together. This allows some slip and so the output shaft (and prop) turns slower than the input from the engine shaft. Fairly obviously it only works with a wet plate clutch to allow for heat dissipation - normal dry clutches as in cars don't like this treatment.
Bejasus
9 Jun 2002
Savannah 32 00.50N - 80 59.90W
Re: trolling valves
Clive, maybe this will help.
'The Newage trolling valve is also available as optional equipment on PRM260, 500, 750, 1000 and 1500 models, enabling propeller speeds to be varied from 1200 rev/min down to zero. This electronically-operated unit is fully inter-changeable with the standard control valve and can be retrofitted in service.
The Newage trolling valve enables low propeller speeds to be obtained by the use of an electrically controlled pressure reducing valve in the clutch pressure operating circuit. It also avoids the use of special oils for the gearbox when fitting the trolling valve.
The operating lever is a Morse type NB unit with locking handle. The housing contains the electrical circuits for operating the trolling valve which again are encapsulated to provide a waterproof seal.
Depressing the ON/OFF switch causes the hydraulic oil to flow through the pressure reducing valve and by varying the position of the control lever the clutch pressure is increased or decreased with an associated increase or decrease in clutch slip. An interlock facility is provided in the form of an electrical connection which can be wired to a microswitch on the fuel rack to switch off the trolling circuit if the engine speed rise above 1200 r.p.m.'
