micknor
New Member
I installed a new ZF 10M gearbox on my Nanni 27hp engine and have had nothing but grief from it over the past 18 months. The engine alignment is spot on, the gear selector moves the specified 35 mm when forward is engaged but after few hours the clutch appears to slip when revs are increased, backing off the revs a little allows full engagement and then things are alright when it has warmed up. Over time this slipping gradually gets worse untill there is basically no forward propulsion when power is increased ie the clutch plates no longer engage.
Has anybody else experienced this problem with a ZF gearbox?
